Trunk only one VLAN to an attached switch
dellpe
Cisco FastHub400
Post by dellpe »
I have a netgear GSM7324 and a managed Cisco WS-C2960-24TT-L switch. I need to connect the Cisco switch to the netgear. The Cisco switch will only need to have vlan 3 on it. Do I still need to set up a trunk port to connect the Cisco and Netgear or would it just set it for switch port mode access and switch access vlan 3 ?
Regards,
Dellpe
Network Engineer
www.huanetwork.com
