Line Appearance with No Ringing
Post by Guest » Mon Oct 06, 2008 8:26 pm
Is there a way on the CallManager 4.1.3 and or the 7960 to have a line appearance with no ringing. For example 1000(line1) will ring if dialed to from the outside or other extensions but 1001(line2) will not ring if dialed to, all on the same phone. I know the Nortel Meridian System can do this easily, unsure if MCS can.
Re:Line Appearance with No Ringing
Post by Guest » Mon Oct 06, 2008 9:40 pm
Yes, in DN configuration you can set the Ring Setting to Disable or Flash Only. Hope this helps. If so, please rate the post.Thanks,Brandon
Post by Guest » Mon Oct 06, 2008 11:17 pm
Works like a charmThanks for your help
