Any difference between Huawei GPON board GPSF and GPHF?
Postby jorna » Sun Jun 18, 2017 11:35 pm
Recently our technical team is evaluating a Huawei next generation OLT MA5800, first configure with 1 16-gpon port board. But i view the price on Alibaba, MA5800 Chassis price is ok, a little higher than ma5600t, but GPON board GPSF and GPHS is much more expensive than GPFD, and also i noted that GPHF is about 100USD higher than GPSF, is there any difference between them?
Cisco 2610XM
Re: Any difference between Huawei GPON board GPSF and GPHF?
Postby hone » Mon Jun 19, 2017 6:52 pm
There are two main difference:
1, different MAX number of MAC address supported:
H901GPSF: 16384
H901GPHF: 131072
2, 1588v2 procotol
GPHF support thia protol, GPSF cannot support.
3, Queue scheduling hierarchy
GPHF 4-level HQoS, GPSF 2-hierarchical HQoS
Actually, GPSF is more popular among people, but if you have high requirement for the above points, then you can consider GPHF for you MA5800 X7 or MA5800 X17.
Cisco 3845
Postby jorna » Tue Jun 27, 2017 6:13 pm
Thanks, very clear!
By the way, do you know where can I find a small-size MA5800 X2, i want to buy one to test firstly, then consider more new Medium size MA5800 X7 and big-size X17.
Cisco 2610XM
Postby hone » Tue Jun 27, 2017 6:49 pm
eee, you can buy it in local, or from China, local price might be higher than in China.
Actually, there are many Huawei OLT ONT dealers in China, the most important is find a reliable one, who has good sell service and technical support.
Cisco 3845
Users browsing this forum: Yahoo [Bot] and 1 guest
