Supporting Task of Resetting Board on Huawei OptiX OSN 2500
Postby jorna » Tue Mar 28, 2017 6:35 pm
A board on Huawei OSN 2500 can be reset in two methods: warm reset and cold reset. A warm reset does not affect the running service, but a cold reset affects the running service.
Resetting Other Boards
When resetting boards, different methods should be applied according to different situations.
Other boards can be reset by using two methods:
Warm or cold reset by NM.
Cold reset by removing and inserting boards.
Resetting Boards by NM
To handle faults of a board, you need to reset the board.
Prerequisites
You must be an NE user with "NE and network operator" authority or higher.
Impact on Services
Performing a warm reset on Huawei N1EFS0, N1EFS4, N2EFS0, N2EGS2, N2EMR0 or N2EGR2
board interrupts the running services on the board. Performing a warm reset on a board of other
types does not affect the running services.
Performing a cold reset on a board affect the running services on the board.
Tools/Instruments
T2000
Procedure
Step 1 In the Main Topology of the T2000 NM, select the NE where a board needs to be reset.
Step 2 Double-click the NE icon to open the NE board layout.
Step 3 Right-click the board to be reset to call the shortcut menu.
Step 4 Click Warm Reset or Cold Reset.
Step 5 Board reset may affect the service, and you should confirm the operation in a prompt dialog box.
Cisco 1760
Re: Supporting Task of Resetting Board on Huawei OptiX OSN 2
Postby hone » Tue Mar 28, 2017 6:42 pm
can you update more information about Huawei OSN2500 supporting tasks?
Cisco Catalyst 3560
