Overview of Huawei FTTx Leased Line Solution
Postby hone » Thu Mar 23, 2017 10:40 pm
Ardware Configuration:
The P2P line board of OLT is OPGD, which can support up to 48 GE/FE optical access;
The Router/LSW in enterprise side can be either Huawei or other standard equipment;
Forwarding mechanism:
If two branches of same enterprise are under same Huawei OLT, the OLT can enable forwarding function between related ports based on same VLAN value;
Else under different OLT, OLT can set up leased line to realize forwarding each other by QinQ VLAN or MPLS PW;
OAM feature
The P2P link can be managed by ETH OAM protocol.
Hardware configuration:
EDTB board in OLT like Huawei MA5683T will be adopted, which can support 16 E1 ports and 16 G.SHDSL ports concurrently in one board;
100% inherit the legacy service, don’t need change
customer premise equipment;
Application Scenarios:
EDTB is mainly applied for extending E1 coverage by transferring to G.SHDSL;
Both TDM G.SHDSL and E1 interface can support PBX access;
E1 for access and TDM PWE3 for uplink can also be applied;
Re: Overview of Huawei FTTx Leased Line Solution
Postby jorna » Tue Mar 28, 2017 6:23 pm
Good sharing, good solution
Cisco 2611XM
