Huawei switch service board ES5D21X02S01
Postby hone » Thu Mar 16, 2017 6:05 pm
Huawei ES5D21X02S01 can be installed in a rear card slot on S5720-C-EI Switch, S5720-PC-EI Switch, provides two 10GE SFP+ optical ports to implement data access and line-speed switching.
ES5D21X02S01 comes with original box, if purchase together with Switch, the module will insert inside Switch by default when delivery, to economical volume weight; If need delivery separately with original box, please contact Thunder-link.com sales team in advance.
2 10GE ports
Apply to Huawei S5720-C-EI Switch, S5720-PC-EI Switch
Supports hot swap
Supports the stack function
Physical size: 100 mm x 208 mm x 40 mm
Weight: 0.78 kg
Cisco Catalyst 3560
