Packet loss at 7609
Packet loss at 7609
Postby isaias.azeredo » Wed Jul 06, 2011 11:45 pm
Hi all,
Could you help me with this?
1. When I perform an extended* ping from the ISP-7600 pointng to the CPE, I have some packet loss.
*ping <cpe_ip> size 1500 repeat 10000
2. If I change the source of extended ping to a device before 7609, for example, I have no packet loss.
3. If I remove the policy in 7600 and keep this as the source of the extended ping, packet loss not happen anymore.
:roll:
The third item is what bothers me. What would explain this situation?
Configurations:
- Routing Protocol: Static
- Interface of the 7600 that points to CPE:
ROTAGG-01#show run int po 20.2001
interface Port-channel20.2001
description Customer_x encapsulation dot1Q 2001
ip address x.x.x.x/30
ip access-group CLIENTES-IN in
no ip redirects
no ip unreachables
no ip proxy-arp
ntp disable
service-policy output 4M
end
ROTAGG-01#show int po20.2001
Port-channel20.2001 is up, line protocol is up (connected)
Hardware is EtherChannel, address is 5475.d0ad.f800 (bia 5475.d0ad.f800)
Description: >> Customer_x
Internet address is x.x.x.x/30
MTU 1900 bytes, BW 2000000 Kbit/sec, DLY 10 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation 802.1Q Virtual LAN, Vlan ID 2001.
ARP type: ARPA, ARP Timeout 04:00:00
Keepalive set (10 sec)
0 packets input, 0 bytes
0 packets output, 0 bytes
Last clearing of "show interface" counters never
ROTAGG-01#show policy-map int po20.2001
Port-channel20.2001
Service-policy output: 4M
Counters last updated 00:00:05 ago
Class-map: POLICY (match-any)
219358438 packets, 200231319082 bytes
30 second offered rate 531000 bps, drop rate 30000 bps
Match: any
0 packets, 0 bytes
30 second rate 0 bps
police:
cir 4000000 bps, bc 125000 bytes
conformed 215826660 packets, 195052293084 bytes; actions:
transmit
exceeded 3531778 packets, 5179025998 bytes; actions:
drop
conformed 822000 bps, exceed 50000 bps
Class-map: class-default (match-any)
0 packets, 0 bytes
30 second offered rate 0000 bps, drop rate 0000 bps
Match: any
0 packets, 0 bytes
Does anyone know what could be the root cause?
isaias.azeredo
Re: Packet loss at 7609
Postby leoghoul » Thu Jan 23, 2014 9:39 am
dear,
Do you have sucess in this problem?
Now, i haved the same problem with CISCO7606-S.
Thks
leoghoul
Postby leoghoul » Thu Jan 23, 2014 9:43 am
hi dear,
Do you haved sucess in this problem ?
Now, I'm the same problem with a CISCO7606-S
thaks
leoghoul
Users browsing this forum: No registered users and 5 guests
