IPCC Call Manager CSS Issue
Post by Guest » Thu Dec 30, 2010 6:56 am
Hi,I have an issue dialling external number as a label in IPCC. It doesn't seem to work eventhough we have assigned enough CSS priviledge to the Route Point if we call from pstn.Here is my setup.1. IPCC 7.1.5 with Call Manager 5.02. I have created Route Point 50000 with CSS_Mobile priviledge (should be able to call external number, including mobile number).3. I created a simple script in IPCC and return a label to external number.When I call the number internally from any ext it's working fine and the call get redirected to the external number.However when I call the RP 50000 from external (example from my mobile), It doesn't work. I've check the logs and what seems to happen is that the ICM returns a correct label to the Call Manager to call however on the 2nd scenario it's trying to use the Calling Party (my mobile) permission instead of the RoutePoint permission and hence it failed.I had to create a route pattern in the Call Manager in order to allow anyone to call to these external number. Is this how it's normally done or do I miss some configuration on the Call Manager?RegardsErwin
Re:IPCC Call Manager CSS Issue
Post by Guest » Thu Dec 30, 2010 7:09 am
The default behavior is to use the calling device's CSS for the redirected calls.  In your case it sounds like you want to use the redirecting device's CSS.  I haven't tried this myself but I believe you will need to change the following registry entry on your PGs.  You will want to use option 2 (ROUTEADDRESS_SEARCH_SPACE).HKEY_LOCAL_MACHINESOFTWARECiscoSystems,Inc.ICMIPCCLPG1BPGCurrentVersionJGWSjgw1JGWDataDynamic"UseRouteAddressSearchSpace"=dword:00000000- Used to control behavior on CTI Route Points for Route Selects.UseRouteAddressSearchSpace can be to set 0, 1, or 2 where :DEFAULT_SEARCH_SPACE = 0CALLINGADDRESS_SEARCH_SPACE = 1ROUTEADDRESS_SEARCH_SPACE = 2Kevin
Post by Guest » Thu Dec 30, 2010 8:08 am
Hi Kevin,Thanks for that. I will certainly try this and let you know the result.Thanks again for the replyRegardsErwin
Post by Guest » Thu Dec 30, 2010 8:43 am
Hi Kevin,Thank you for your help. I have tested this and it's working as per your recommendation.Thanks again!Erwin
