Disaster 877 has only romon and conflict ip, need help?
Re:Disaster 877 has only romon and conflict ip, need help?
Post by Guest » Wed Oct 21, 2009 8:01 am
At Rommon>1 cut and paste the following. It *must* be uppercase. IP_ADDRESS=10.10.10.1IP_SUBNET_MASK=255.255.255.0DEFAULT_GATEWAY=10.10.10.2TFTP_SERVER=10.10.10.2TFTP_FILE=filename.binType "set" to verify the above.On your laptop/PC with the tftp server, manually set the network card for an IP address of 10.10.10.2 a netmask of 255.255.255.0 and default gateway of 10.10.10.1. Verify this with ipconfig in cmd window. You cannot have the tftp server and router with the same IP address, this is the conflict that you see.Ensure the file filename.bin is in the expected directory and launch tftpdnld or the equivalent command from Rommon> on the router.Let us know how it goes.
Post by Guest » Wed Oct 21, 2009 9:31 am
Sorry, it didn't work.I know how to be sure with uppercase lately, 2 days ago.At first, tftp32 is smart, whenever I change IP_ADDRESS, it will follow that IP. So I use Solarwinds which cannot change IP when I try to change another one.Here are my logsrommon 7 > set              PS1=rommon ! >              TFTP_TIMEOUT=800000                   FE_SPEED_MODE=4               TFTP_RETRY_COUNT=20                   ?=0   ROM_PERSISTENT_UTC=1208230997                             RET_2_RTS=BSI=0RET_2_RCALTS=RANDOM_NUM=1921062664IP_ADDRESS=10.10.10.1IP_SUBNET_MASK=255.255.255.0DEFAULT_GATEWAY=10.10.10.2TFTP_SERVER=10.10.10.2TFTP_FILE=124-20T1.binTFTP_CHECKSUM=0rommon 8 > tftpdnld          IP_ADDRESS: 10.10.10.1      IP_SUBNET_MASK: 255.255.255.0     DEFAULT_GATEWAY: 10.10.10.2         TFTP_SERVER: 10.10.10.2           TFTP_FILE: 124-20T1.binDo you wish to continue? y/n:  [n]:  y,,,,,,,,ARP: address resolution for 10.10.10.2 timed out.ARP failed with failure code 3.  TFTP transfer aborted.TFTP: Operation terminated prematurely.The problem is how to get rid of the same ip of network card and tftp server.Noted: xmodem didn't work for me, even with small file ROMMON update about 650K.I also change the name of IOS shorter and simple to avoid error of typo.Thanks in advance.
karterlee123
Re: Disaster 877 has only romon and conflict ip, need help?
Post by karterlee123 » Fri Jun 22, 2012 10:54 am
Hi, you have the wireless router IP_ADDRESS set the same as the tftp hosting server.
Change the wireless router to IP_ADDRESS=10.1.0.2 and DEFAULT_GATEWAY=10.1.0.1 and try it again.
