Disaster 877 has only romon and conflict ip, need help?
Postby Guest » Wed Oct 21, 2009 5:50 am
Hi
My mistake is to format my flash. After 1 day to read without successfull finding solution. I really need your expert opinions.
I download new IOS and decide to format flash. After that I can only have rommon prompt.
I read some articles. I download tftp server like Solarwinds or tftp32, install it. Then I manual set ip to my network card like 10.1.0.1 with subnet: 255.255.255.0, gateway: 10.1.0.2. I start tftp program and it always have the same ip of my network card, that means ip of tftp server is now: 10.1.0.1.
In console, I set:
IP_ADDRESS:10.1.0.1
IP_SUBNET_MASK:255.255.255.0
DEFAULT_GATEWAY:10.1.0.2
TFTP_SERVER:10.1.0.1
TFTP_FILE:124_20T.BIN
Result: from console I always get : Operation terminated [TIME OUT].
Specially, in the log of tftpd32 I have the message: error 10054 in system call recv An existing connection was forcibly closed by the remote host.
I have the same problems when trying to use xmodem option, then I get the same message time out everytime.
If you have any opions, please advice me step by step to recover my IOS to flash.
Thanks in advance
Re:Disaster 877 has only romon and conflict ip, need help?
Postby Guest » Wed Oct 21, 2009 6:25 am
I'd say, ensure your TFTP server doesn't have a firewall blocking the traffic.
Also, you need to ensure you are using the first/loweest numbered interface for connectivity.
See the following for more detail on downloading from TFTP within ROMMON:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bf9e.shtml
HTH
Cheers
Scott
Postby Guest » Wed Oct 21, 2009 6:30 am
Hi
Thanks for response
But my windows firewall has turned off.
And I use crossover cable to connect to FE0.
Any ideas
Postby Guest » Wed Oct 21, 2009 6:37 am
Hi, you have the router IP_ADDRESS set the same as the tftp server.
Change the router to IP_ADDRESS=10.1.0.2 and DEFAULT_GATEWAY=10.1.0.1 and try it again.
Hope this helps.
Postby Guest » Wed Oct 21, 2009 7:04 am
Hi
Thansk for response.
I know the fact that I have IP_ADDRESS set the same as the tftp server IP. But I cannot change it. Somewhere on internet, they say it's O.K, I don't know it's true or not.
Here're my steps:
1. Get IP_ADDRESS manually to have:
10.10.10.2/255.255.255.248 with gate: 10.10.10.1
2. Double click tftp32 or Solarwinds tftp free, all of them get always the ip of my IP_ADDRESS. That means 10.10.10.2
3. In console set up IP_ADDRESS, IP_SUBNET_MASK, DEFAULT_GATEWAY, TFTP_SERVER, TFTP_FILE, then finally press Enter when you re typing tftpdnld -u.
Result: Time out in console, windows popup Ip conflict, tftp32 has above message.
2nd chance:
1. Setup IP manually like: 10.10.10.2/255.255.255.248 Gateway: 10.10.10.1
2. Turn on tftp server, it will get the same ip of my IP_ADDRESS: 10.10.10.2
3. Setup again manual IP like you said before to have: 10.10.10.1/255.255.255.248 gateway now is 10.10.10.2
4. Go to console setup as above details.
Result: it doesn't work too. the same message is Time out and ip conflict.
Even with xmodem, I still cannot get it. It will have always Time out or cannot connect. But I still have character clearly Rommon 1> and other info in my display console.
Any ideas.
Users browsing this forum: No registered users and 7 guests
