New Cisco ASA 5506-X will replace ASA 5505
Postby Emma Jing » Thu Apr 09, 2015 7:39 pm
Cisco ASA 5506-X ASA5506-K9 firewall is supposed to have the FirePOWER engine and also equipped with Gigabit ports. The FirePOWER module (most probably will be a software module on the low-end modules) offers next-generation firewall services, including Next-Generation Intrusion Prevention System (NGIPS), Application Visibility and Control (AVC), URL filtering, and Advanced Malware Protection (AMP).
Emma Jing
Cisco 2501
Re: New Cisco ASA 5506-X will replace ASA 5505
Postby bella007 » Tue Apr 28, 2015 11:37 pm
I recall that the ASA 5505 only supported inside and outside interfaces, can you confirm that the 5506-X supports 3 interfaces?
3Anetwork is a leading Global provider of Cisco networking products.
bella007
Cisco FastHub400
Return to Cisco Security
