Problem whit 3560 and tacacs
martinadasme
Cisco FastHub400
Post by martinadasme » Tue Jul 05, 2011 8:40 am
I have a 3560 trunked to 3750 stack. The 3560 get ping to tacacs (in debian) and the same for tacacs to 3560. so I have connectivity.
But the 3560 no logging whit tacacs, anda i dont now why, please help me!!! The 3750 work whit tacacs and have the same configuration, and others 2960/3750 works whit this configuration
In the tacacs the line for this host was write.
host = 10.185.133.97 {type = cisco key = Turner }
host = 10.185.133.42 {type = cisco key = cssturner }
host = 10.185.133.116 { type = cisco key = Turner }
host = 10.185.136.59 { type = cisco key = Turner }
the configuration of the 3560 is:
aaa new-model
aaa authentication login default group tacacs+ local enable
aaa authorization exec default group tacacs+ local
aaa accounting suppress null-username
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default stop-only group tacacs+
aaa accounting commands 1 default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa session-id common
interface GigabitEthernet0/48 trunk to 3750
description connection to rt-g1cer-b
switchport trunk encapsulation dot1q
switchport trunk allowed vlan 2-900
switchport mode trunk
udld port aggressive
interface Vlan521
ip address 10.185.136.59 255.255.255.192
interface Vlan524
ip address 172.16.153.171 255.255.255.0
ip default-gateway 10.185.136.1
ip classless
ip route 0.0.0.0 0.0.0.0 10.185.136.1
ip http server
ip tacacs source-interface Vlan521
logging trap notifications
logging facility local6
logging source-interface Vlan521
logging 10.185.133.60
snmp-server community cssturner RO 99
snmp-server community cssRWTurner RW 99
snmp-server ifindex persist
snmp-server trap-source Vlan521
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps tty
snmp-server host 10.185.133.60
tacacs-server host 10.185.133.60
tacacs-server directed-request
tacacs-server key 7 XXXXX
radius-server source-ports 1645-1646
line con 0
line vty 0 4
password 7
line vty 5 15
password 7
The debug in the 3560:
Jul 5 14:21:37.086: AAA/ACCT/CMD: User turner, Port tty1, Priv 15:
"terminal monitor <cr>"
Jul 5 14:21:37.086: AAA/ACCT/CMD: Found list "default"
Jul 5 14:21:37.086: AAA/ACCT: user turner, acct type 3 (732008493): Method=tacacs+ (tacacs+)
Jul 5 14:21:37.086: TAC+: Opening TCP/IP to 10.185.133.60/49 timeout=5
Jul 5 14:21:37.086: TAC+: Opened TCP/IP handle 0x39399E0 to 10.185.133.60/49 using source 10.185.136.59
Jul 5 14:21:37.086: TAC+: periodic timer started
Jul 5 14:21:37.086: TAC+: 10.185.133.60 req=3814FF0 Qd id=732008493 ver=192 handle=0x39399E0 expire=5 ACCT/REQUEST/STOP queued
Jul 5 14:21:37.187: TAC+: 10.185.133.60 id=732008493 wrote 142 of 142 bytes
Jul 5 14:21:37.187: TAC+: 10.185.133.60 req=3814FF0 Qd id=732008493 ver=192 handle=0x39399E0 expire=4 ACCT/REQUEST/STOP sent
Jul 5 14:21:37.287: TAC+: 10.185.133.60 read=12 wanted=12 alloc=12 got=12
Jul 5 14:21:37.287: TAC+: 10.185.133.60 read=17 wanted=17 alloc=17 got=5
Jul 5 14:21:37.287: TAC+: 10.185.133.60 received 17 byte reply for 3814FF0
Jul 5 14:21:37.287: TAC+: req=3814FF0 Tx id=732008493 ver=192 handle=0x39399E0 expire=4 ACCT/REQUEST/STOP processed
Jul 5 14:21:37.287: TAC+: periodic timer stopped (queue empty)
Jul 5 14:21:37.287: TAC+: Closing TCP/IP 0x39399E0 connection to 10.185.133.60/49
the tcpdump in the tacacs :
aaadns1 ~ # tcpdump -nni bond0 host 10.185.136.59
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on bond0, link-type EN10MB (Ethernet), capture size 68 bytes
11:59:06.079879 IP 10.185.136.59.11525 > 10.185.133.60.49: S 790869469:790869469(0) win 4128 <mss 536>
11:59:06.079895 IP 10.185.133.60.49 > 10.185.136.59.11525: S 1696757733:1696757733(0) ack 790869470 win 5840 <mss 1460>
11:59:06.230097 IP 10.185.136.59.11525 > 10.185.133.60.49: . ack 1 win 4128
11:59:06.389137 IP 10.185.136.59.11525 > 10.185.133.60.49: P 1:132(131) ack 1 win 4128
11:59:06.389146 IP 10.185.133.60.49 > 10.185.136.59.11525: . ack 132 win 6432
11:59:06.389222 IP 10.185.133.60.49 > 10.185.136.59.11525: P 1:18(17) ack 132 win 6432
11:59:06.389233 IP 10.185.133.60.49 > 10.185.136.59.11525: F 18:18(0) ack 132 win 6432
11:59:06.421249 IP 10.185.136.59.11525 > 10.185.133.60.49: . ack 19 win 4111
11:59:06.546583 IP 10.185.136.59.11525 > 10.185.133.60.49: FP 132:132(0) ack 19 win 4111
11:59:06.546597 IP 10.185.133.60.49 > 10.185.136.59.11525: . ack 133 win 6432
12:00:01.150846 IP 10.185.136.59.123 > 10.185.133.61.123: NTPv3 client, strat 3, poll 6, prec -18
12:00:01.150862 IP 10.185.133.61.123 > 10.185.136.59.123: NTPv3 server, strat 2, poll 6, prec -20
12:01:05.148673 IP 10.185.136.59.123 > 10.185.133.61.123: NTPv3 client, strat 3, poll 6, prec -18
12:01:05.148687 IP 10.185.133.61.123 > 10.185.136.59.123: NTPv3 server, strat 2, poll 6, prec -20
12:02:09.154809 IP 10.185.136.59.123 > 10.185.133.61.123: NTPv3 client, strat 3, poll 6, prec -18
12:02:09.154825 IP 10.185.133.61.123 > 10.185.136.59.123: NTPv3 server, strat 2, poll 6, prec -20
12:03:13.152589 IP 10.185.136.59.123 > 10.185.133.61.123: NTPv3 client, strat 3, poll 6, prec -18
12:03:13.152603 IP 10.185.133.61.123 > 10.185.136.59.123: NTPv3 server, strat 2, poll 6, prec -20
18 packets captured
18 packets received by filter
0 packets dropped by kernel
HELP ME PLEASE!!!!! THANKS......
