Mac address based authentication with TACACS
Post by Guest » Sun Jul 09, 2006 4:53 am
Hello everyone!I know there is a change in RADIUS to authenticate a user using his mac-address. Is it possible with TACACS?
Re:Mac address based authentication with TACACS
Post by Guest » Sun Jul 09, 2006 5:34 am
The MAC Address authentication works only in an EAP Protocol environment, TACACS does not support EAP. Here is an old discussion about the above statement:https://learningnetwork.cisco.com/message/8820Hope this helps,
Post by Guest » Sun Jul 09, 2006 5:44 am
Thank you for your answer and the link.Everyone says EAP is not supported in TACACS, but there is EAP configuration in TACACS, especially PEAP, LEAP and etc.
Post by Guest » Sun Jul 09, 2006 6:37 am
EAP for TACACS? Do you see it in ACS? Could you instruct us where that is?
Post by Guest » Sun Jul 09, 2006 6:59 am
Sure. Go to System Configuration, and then to Global Authentication Setup, you will find PEAP, LEAP and other EAP settings
