exterlan LED satus 1131AG - turn it off
Postby Guest » Sun Dec 05, 2010 1:36 pm
hi
this weeken i setup a wireless network in a large house and everything is working perfectly. the only complaint i received was that hte external led light is very bright when it gets dark (as it is located in one of the bedrooms this is a bit of an issue)
i found the following command
AP1(config)#led display ?
  dim  Turn LED display dim.
  off  Turn LED display off.
AP1(config)#led display off
i applied the above command but i have no way of veryfing (as i am not on site) if the external led has now turned off.
i could not find a command to show me the current led status (on/off/dim)
so 2 questions
1) will this command have turned off the external LED
2) how can you verify via the command line what the current status is
many thanks
Re:exterlan LED satus 1131AG - turn it off
Postby Guest » Sun Dec 05, 2010 1:38 pm
Hi Rogier,
Yes, this command should have fully darkened the LED Display;
This example shows how to turn-off the 1130AG Status LED:
AP(config)# led display off
http://www.cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/command/reference/cr43main_external_docbase_0900e4b180443057_4container_external_docbase_0900e4b180480623.html#wp3339779
This should be seen in a "show run" for the AP
Hope this helps!
Rob
Re: Re:exterlan LED satus 1131AG - turn it off
Postby RodneyNewton » Tue Sep 03, 2013 3:23 am
Guest wrote:Hi Rogier,Yes, this command should have fully darkened the LED Display;This example shows how to turn-off the 1130AG Status led lights:AP(config)# led display off This should be seen in a "show run" for the APHope this helps!Rob
Ya it helps for sure.. I am facing similar issue but I tried your way out and it was sorted out.. Thanks
RodneyNewton
Return to Cisco Wireless
