Setup FXS port for use with analog phone
Postby AlistairCarr » Mon Jun 03, 2013 7:03 am
Hi, I'm trying configure a very basic FXS port for use with an analogue phone
config on for the dial peer is as follows
dial-peer voice 30 pots
destination-pattern 276
port 0/1/0
fxs port configuration is below
voice-port 0/1/0
trunk-group 1
description Walkabout Phone
If i connect an analog phone to the port none of the LED's on the FXS light up,
If i call 276 from an ip handset the handset does not ring however i get the ringing tone in the phone that im using to try and call the analog handset.
If I shutdown the port and then try to call 276 from an IP handset again i get the number doesn't exist tone (I think it is)
I think the config is correct on the CME (2811 )
Stuck as to whats going on ?
Thanks in advance,
AlistairCarr
Return to Cisco IP Communications
