Voicemail forwarding
Postby Loki481 » Fri Nov 11, 2011 4:27 am
I'm having some trouble with the voicemail in the CME. The config for the DN and Phone are below, with the personal details hashed out.
The problem is that when you dial his internal number it goes to his voicemail which is what we want., but when you dial his DDI (secondary) number, you get forwarded onto someone else.
Anyone got any ideas?
!ephone-dn 2 dual-line number 3602 secondary ###
pickup-group 1
label ########
name ########
call-forward busy 800
call-forward noan 800 timeout 15
ephone 2
device-security-mode none
mac-address 0027.0DBD.D98D
ephone-template 1
username "####" password 3602
type 7942
auto-line 1 answer-incoming
button 1:2 2:89
Loki481
Re: Voicemail forwarding
Postby kiarajeckson » Fri Sep 14, 2012 2:37 am
I think there is a problem in the network connection or may be the system settings is not proper.Firstly you should check your internal settings of the system and if it is correct then you should contact with customer care service.
kiarajeckson
Return to Cisco IP Communications
Users browsing this forum: Google Adsense [Bot] and 2 guests
