Extension Mobility Error [25]
Re:Extension Mobility Error [25]
Post by Guest » Sat Oct 06, 2007 10:22 pm
Hi,something that you may want to try is to visit the SEP profile of the phone and there you will found a logout button. Well, for me is how this work. You can see in the picture bellow a example.After that you can configure a extension mobility policy saying that when the user subscribes again the other one will be disconnected.Thanks!
Post by Guest » Sat Oct 06, 2007 10:45 pm
Thank you!
iphtechnologies
Re: Extension Mobility Error [25]
Post by iphtechnologies » Fri Jan 19, 2018 2:44 am
Locale change may provide the basis for reset.
If the User Locale that is associated with the login user or profile is not the same as the locale or device, after a successful login, the phone will perform a restart that is followed by a reset. This occurs because the phone configuration file is being rebuilt.
iPhone App Development Company India
Enterprise Mobility Software Solutions
