CME Install Question
Post by Guest » Fri Dec 24, 2010 2:36 am
Sorry for the basic question but I am trying to install CME 7.0(1) on an ISR running IOS ver C-2801-IPVOICEK9-M Version 12.4(25) rel fc2.  So far I have donwloaded the file "cme-full-7.0.0.1.tar" and extracted it's contents to flash and rebooted after following the readme files instructions.  My phones all came up ok but the problem is when I run "show telephony-service" it says I am running cme "Version 3.3"  I'm not clear on what else I have to do here?  Should it not say Verion 7.01 or similar?
Re:CME Install Question
Post by Guest » Fri Dec 24, 2010 3:29 am
You need to update IOS to the latest T version for CME 7.xThe files in flash are just phone firmware, GUI, etc, are accessories and do not make the real thing - that is IOS.
Post by Guest » Fri Dec 24, 2010 3:37 am
Makes sense... Thanks!
Post by Guest » Fri Dec 24, 2010 5:00 am
You're welcome, thanks for the appreciation and good luck.
