Two networks, One Server
Postby silverskymedia » Wed May 11, 2011 8:42 am
I have a set of servers that I want to set on two distinct networks.
The justification is: 1) Last Mile Network Redundancy 2) Load Balancing
It is very unlikely we will be allowed to run BGP for external routing so we're going to just do round-robin DNS. So we will have two distinct IP address ranges for each network. For the purposes of this question well say (Net1 = 60.25.33.128/28) and (Net2 = 152.22.23.0/28). I would also like to run OSPF (or some other internal routing) to balance between the two lines. I have a Cisco 2800 (2811) to route between the networks.
The Cisco router is currently configured to use 1 to 1 NAT (ip nat inside source static network 172.16.1.0 60.25.33.128 /28). With this configuration I am working fine on Net1. The problem is that when I bring in the second network I anticipate trouble. For one if I run the command ip nat inside source static network 172.16.1.0 152.22.23.0 /28 (if it will let me do that) the NAT is overlapped. And while the server won't know which network the traffic has originated (good thing) the router will not know which IP address to put back on the IP header which would make requests coming from the secondary network unable to receive a response.
If, however I were to do ip nat inside source static network 172.16.2.0 152.22.23.0 /28 instead (creating a new internal network) and just assign the server a 172.16.1.x and a 172.16.2.x IP address then that would fix the NAT problem but at that point I'm not sure the router will be able to effectively route packets through the best network available. The networks have very different line speeds and because the internal routing is round-robin DNS there could be a better return route. That is to say it should be fine for a packet that originated from the 60.25.33.128 network to be routed back through the 152.22.23.0 network so long as I preserve the originating IP address header.
Any ideas on the best way to configure the network / Cisco 2800 router to achieve my goal?
Thanks!
silverskymedia
Re: Two networks, One Server
Postby john » Fri May 27, 2011 12:58 pm
two nics on each server.
Nic 1
Nic2
The router can do the rest. traffic going into the server will be sent out the same interface. (lining up the ips)
With round robin if one line is down wont you still be dropping half your traffic?
John
john
Site Admin
CCM server QoS
Forum: Quality of Service
Author: Anonymous
SNMP server configuration
Forum: Routing Protocols
Author: m_1607
ASA5510 Remote access Server problem
Forum: Virtual Private Networks
Author: Anonymous
Ping to PAT internal server on ASA 5510
Forum: Cisco Security
Author: Anonymous
HUM and CSM in the same server?
Forum: Network Management
Author: Anonymous
Return to Routing Protocols
