HSRP
HSRP
Postby Guest » Fri Dec 31, 2010 7:40 am
hi all & happy new year to u all.
i am gonna use two Layer 3 switches, gonna configure hsrp and OSPF on them. I want end user PCs to connect directly to those L3 switches. Question is, do i have to use a third switch in order to make HSRP work? or without using a third switch, an uplink between two switches would be enough for HSRP?
i appreciate any help, tx in advance.
Re:HSRP
Postby Guest » Fri Dec 31, 2010 7:54 am
HSRP requires L2 conectivity between the two routers (or L3 switches). So HSRP would work in case you have a trunk between the Switches for all VLANs with HSRP required. A third switch is not nessessary.
What I would recommend to read is also:
Understanding and Troubleshooting HSRP Problems in Catalyst Switch Networks
http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a0080094afd.shtml
Hope this helps
Martin
Re:HSRP
Postby Guest » Fri Dec 31, 2010 8:42 am
tx martin.
Re:HSRP
Postby Guest » Fri Dec 31, 2010 9:44 am
Greetings fellow sadikhov'er
Re:HSRP
Postby Guest » Fri Dec 31, 2010 10:54 am
A very happy new year to you
Are you going to connect PCs direcly to L3 switch modules.  In this scenario, say if one L3 fails (power supply failure) then, even if HSRP keeps running betn two L3 switches, your PCs will not have any redundant path to the other core.  So anyway the PCs will loose network connectivity.
You can use an access switch to connect PCs and then youcan provide uplinks to each core from this access switch
Hope this helps
HSRP load-balancing ?
Forum: Routing Protocols
Author: Anonymous
HSRP Tracking question
Forum: Anything Networking
Author: Anonymous
HSRP on one Router?
Forum: Cisco Switching
Author: Anonymous
Same HSRP Groups on multiple physical interfaces
Author: Anonymous
DMVPN Hub on HSRP standby router
Forum: Network Management
Author: Anonymous
Return to Routing Protocols
