U2000 didn't work normally because of database issue
Postby hone » Mon Mar 06, 2017 7:25 pm
Issue Description
In the HA system, the primary and the secondary in the lab was separated. Started the U2000, but it can’t work normally. There was no alarm any more. The database seemed to be good after checking by VCS tool.
Alarm Information
null
Handling Process
After discuss with customers, we decided to initialize the database and then restore the U2000 by the script. Before perform this, need to fix alarmdb. Here is the procedure as below.
1.delete the alarmdb:
#su - sybase
$isql -Usa -Psybase -SDBSVR
>use master
>go
>drop database alarmdb
>go
>sp_dropdevice faultdb_nms_dev
>go
>sp_dropdevice faultdb_nms_dev1
>go
>sp_dropdevice faultdb_nmslog_dev
>go
>sp_dropdevice bmsdb_nms_dev
>go
>go
2.  delete the device file relating to the database
$cd /opt/sybase/data
$rm lv_faultdb_nms_dev
$rm lv_faultdb_nms_dev1
$rm lv_faultdb_nmslog_dev
3.  create the database
>use master
>go
>disk init
>name="faultdb_nms_dev",
>physname="/sybase/data/lv_faultdb_nms_dev",
>size="1200m"
>go
>disk init
>name="faultdb_nmslog_dev",
>physname="/sybase/data/lv_faultdb_nmslog_dev",
>size="600m"
>go
4.  initialize the database by the Msuit
5.  restore the info by U2000 script
Root Cause
Log into the system monitor and noticed that fault process wasn’t running. Connected to database and found alarmdb was offline. And there was no free space in the alarmdb log which caused the whole alarmdb can’t be read or written normally.
Suggestions
null
Re: U2000 didn't work normally because of database issue
Postby jorna » Tue Mar 07, 2017 7:40 pm
Really cannot understand, can you told more details, your contact information?
Cisco 2611XM
Postby jorna » Thu Mar 30, 2017 6:09 pm
database issue, you can contact Technical persons at Thunder-link.com, very professional
Cisco 2611XM
Return to Any Other Topic
