HUAWEI S2309TP-EI-AC FAQ
Postby jorna » Wed Mar 01, 2017 7:01 pm
Q: What is the difference between S2309TP-EI-AC and LS-S2309TP-SI-AC?
A: Basically LS-S2309TP-SI-AC only supports simple Lay-2 access functions, while LS-S2309TP-EI-AC provides more powerful VLAN, QoS, multicast, security, authentication, and reliability functions.
Q: Can I get technical support from Thunder-link.com if we purchase LS-S2309TP-EI-AC from you?
A: Yes, Thunder-link.com has experienced technical team on Huawei switches, however, you may need to purchase technical support service from us as by default we only provide one year hardware warranty.
Q: Why failure to create VLANIF interfaces of other VLANs?
A:
This problem is caused by the VLANIF interface corresponding to the default VLAN (VLAN 1) of the system. Therefore, you must delete the VLANIF interface of VLAN 1 before configuring VLANIF interfaces of other VLANs.
[S2300]undo interface Vlanif 1
[S2300]interface Vlanif 3
[S2300]ip address 1.1.1.1 255.255.255.252
The configuration succeeds.
Q: Does the S2300 switch support PoE?
A:
In V100R001 and V100R002, none of the Switches support the PoE function.
In V100R003C00 and later versions, the following models of the Switch support the PoE function:
S2326TP-PWR-EI
S2309TP-PWR-EI
Q: How to delete all configurations of the Huawei S2300?
A:
To delete all the configurations, delete the vrpcfg.cfg file from the flash memory, and then restart the S2300. The vrpcfg.cfg file cannot be deleted when it is running because it is used as the system file. To delete the file forcibly, perform the following steps:
1.Restart the S2300 and press Ctrl+B to enter the BootROM menu, and then enter the default password huawei.
2.Press Ctrl+Z to enter the hidden menu, and then select option 2 to enter flash memory.
3.Delete the vrpcfg.cfg file from the flash memory, and then restart the device.
Q: Does the S2300 support stacking?
A: The S2300 does not support stacking. Later versions of V100R003 support the HGMP cluster.
Q: How to configure load balancing in a link aggregation group of SW2300?
A:
· V100R001
Run the load-balance { dmac | smac | smacxordmac } command in the Eth-Trunk view.
The default load balancing mode is smacxordmac.
·V100R002 and V100R003
Run the load-balance { dmac | smac | smacxordmac | sip | dip | sipxordip } command in the Eth-Trunk view.
· V100R005 and V100R006
Run the load-balance { dst-ip | dst-mac | src-ip | src-mac | src-dst-ip | src-dst-mac } command in the Eth-Trunk view.
The default load balancing mode of the S3300HI, S5300HI, S5306, and S6300 is src-dst-ip; the default load balancing mode of other switches is src-dst-mac.
Cisco 2611XM
Re: HUAWEI S2309TP-EI-AC FAQ
Postby hone » Thu Mar 02, 2017 6:17 pm
Huawei switch is very good, last month, i sold 6 sets S6720 to my Chilean customer. He said S6720 has better performance than S6700, and price are the same. if you need Huawei hardware products, such as GPON OLT, ONT, SWITCH or Router, you can contact Daisy@thunder-link.com.
Return to Any Other Topic
