Huawei OTN Line Board TN54NS3T01
Postby hone » Mon Feb 27, 2017 7:05 pm
Huawei OTN TN54NS3T01 is a 40G Line Service Processing Board, converts 32*ODU0, 16*ODU1, 4*ODU2 and 1*ODU3 into one OTU3 signal. TN54NS3T01 part number is 03030LWM, some other version like TN11, TN52, TN55, and TN56 with different system compatibility and feature supported. TN54NS3 has feature code like T01 and T03, different line code.
1, 40G Line Service Processing Board(AFEC DQPSK,Tunable), 50GHz(Rx1_PIN,Tx1_-5dBm~0dBm,LC)
2, The NS3 board achieves cross-connection at the electrical layer and to provide OTN interfaces and ESC.
3, The NS3 board can work in either line mode or relay mode.
4, Supports the OTU3/OTU3e interface on the WDM side.
5,Supports the OTN frame format and overhead processing by referring to the ITU-T G.709.
6,OTU3 layer:supports the SM function.
7,ODUk(k=0, 1, 2, 3, flex) layer supports the PMand TCM function, and PM and TCM non-intrusive monitoring functions.
8,80 wavelengths tunable in the C band with 50 GHz channel spacing
9,Supports ESC function
10,Supports the PRBS function on the WDM side.
11, Supports ITU-T G.709-compliant forward error correction (FEC) on the WDM side.
12, Supports ITU-T G.975.1-compliant AFEC-2 on the WDM side.
13, The WDM-side signals of the TN54NS3 board can be regenerated using another TN54NS3 board.
14, Supports IEEE 1588V2 at BC and OC mode, do not support TC and TC+OC mode.
15, Supports Optical-layer ASON and Electrical-layer ASON (OTN)
16, OTN protection, Supports ODUk SNCP.
17, Supports intra-board 1+1 protection (when working with the OLP/DCP/QCP board).
18, Supports ODUk SPRing protection.
19, Supports tributary SNCP protection.
20, Supports OWSP protection.
21, Supports SDH protection, SNCP, SNCTP, LMSP, MSP ring
22, Supported Loopback at WDM side and ODU0/ODU1/ODU2 Channel Loopback
TN54NS3T01 can be applied in Huawei OTN OSN8800 OSN6800.
Re: Huawei OTN Line Board TN54NS3T01
Postby jorna » Wed Mar 01, 2017 6:36 pm
HUAWEI 40G or 100G line board is very expensive, but we can find them in some special channels with very reasonable price. there are many dealer in China, such as Thunder-link.com, a very professional supplier
Cisco 2611XM
Return to Any Other Topic
