WDM ALC management window problem in U2000 V100R003C00SPC102
Postby jorna » Mon Feb 20, 2017 8:59 pm
Issue Description
During implementation of ALC function for Huawei OSN 8800 equipment engineer found that "NG WDM complete link" tab is absent in WDM ALC management window. In this case it is impossible to check NG-WDM complete links and start Automatic link adjustment.
U2000 version: V100R003C00SPC102
Please refer to attachment "before pacth".
Alarm Information
null
Handling Process
Install patch for U2000 client. Get patch from HQ.
Root Cause
Engineer checked configuration guide and found that real U2000 window is different from document
After escalation of this problem, HQ suggested to install specific patch for U2000 client
After patch installation problem was solved, we observed needed tab in ALC management window.
please refer to attachment "after patch".
Suggestions
Each U2000 client of version V100R003C00SPC102 should have this patch installed for correct execution of ALC functions.
Cisco 1760
Re: WDM ALC management window problem in U2000 V100R003C00SP
Postby hone » Mon Feb 27, 2017 6:55 pm
aaaaa, HUAWEI WDM equipment is very professional, and they are very popular around the world.
but it is very expensive, hope huawei can adjust the price in the future.
Cisco Catalyst 3560
Postby jorna » Wed Mar 01, 2017 6:45 pm
managing U2000 is very difficult.
Cisco 1760
Return to Any Other Topic
