Why QSFP+ module doesn't work when connect with patch cord?
Linksys, Netgear, ect. Webbase configurations for switches or layer 2 devices.
Postby hone » Tue May 16, 2017 7:07 pm
I bought 2 pcs QSFP+ modules last week, used on my S6720-30C-EI-24S-AC switch, but when I connect it with patch cord, it doesn't work, I checked switch and QSFP+ are good, I really do not know where is the problem. :cry:
Cisco 3845
Re: Why QSFP+ module doesn't work when connect with patch co
Postby jorna » Wed May 17, 2017 6:28 pm
Before i encountered same problem with you. I though the QSFP+ itself does not work.
Later i consult offcial Huawei, they told me that the patch cord on 40G QSFP+ is different from the usually cord we use, need purchase separately.
Finally, I bought 40G qsfp patch cord locally, then my Huawei S6720-54C-EI-48S works well, and i think Huawei products goes more and more popular.
Cisco 2610XM
Return to Small Business Switches
