HUAWEI S5700S-LI SERIES GIGABIT ENTERPRISE SWITCHES
Linksys, Netgear, ect. Webbase configurations for switches or layer 2 devices.
Postby jorna » Tue Feb 14, 2017 6:54 pm
Product Overview
Huawei S5700S-LI series has two models that are S5700S-28P-LI-ACand S5700S-52P-LI-AC
S5700S-LI series gigabit enterprise switches (S5700S-LI for short) are next-generation energy-saving switches developed by Huawei to meet the demand for high-bandwidth access and Ethernet multi-service aggregation. Based on the cutting-edge hardware and Huawei Versatile Routing Platform (VRP) software, the S5700S-LI provides a large switching capacity and high-density GE ports. The S5700S-LI is for use in various enterprise network scenarios. For example, it can function as an access or aggregation switch on a campus network, a gigabit access switch in an Internet data center (IDC), or a desktop switch to provide 1000 Mbit/s access for terminals. The S5700S-LI is easy to install and maintain, reducing workloads for network planning, construction, and maintenance. The S5700S-LI uses advanced reliability, security, and energy conservation technologies, helping enterprise customers build a next generation IT network.
Product Features and highlights
1,Innovative Energy Saving Design
Huawei S5700 offer customers extensive selection of energy-saving with standard mode, basic mode and advanced mode that accommodates most needs. By matching port link down/up, optical-module in-place/out of place, port shut down/undo shutdown, idle/busy period to increase the proportion of the dynamic energy-saving to reduce the power consumption. The S5700S-LI series reduces energy consumption without compromising system performance, ensuring good user experience. The S5700-LI adopts multiple cutting-edge energy-saving designs, including Energy Efficient Ethernet (EEE), port energy detection, dynamic CPU frequency adjustment, and device sleeping.
2, Comprehensive reliability mechanism
Besides STP, RSTP, and MSTP, the S5700S-LI supports enhanced Ethernet reliability technologies such as Smart Link and RRPP (Rapid Ring Protection Protocol), which implement millisecond-level protection switchover and ensure network reliability. It also provides Smart Link multi-instance and RRPP multiinstance to implement load balancing among links, optimizing bandwidth usage.
Well-designed QoS policies and security mechanisms
The S5700S-LI implements complex traffic classification based on packet information such as the 5-tuple, IP precedence, ToS, DSCP, IP protocol type, ICMP type, TCP/UDP port number, VLAN ID, Ethernet protocol type. ACLs can be applied to inbound or outbound direction on an interface. The S5700S-LI supports a flow-based two-rate three-color CAR. Each port supports eight priority queues and multiple queue scheduling algorithms such as WRR, DRR, SP, WRR+SP, and DRR+SP. All of these ensure the quality of voice, video, and data services.
3, Easy deployment and maintenance free
The S5700S-LI supports automatic configuration, plug-and-play, and batch remote upgrade. These
capabilities simplify device management and maintenance and reduce maintenance costs. The S5700SLI supports SNMP v1/v2c/v3 and provides flexible methods for managing devices. Users can manage the S5700S-LI using the CLI and web-based NMS. The NQA function helps users with network planning and upgrading. In addition, the S5700S-LI supports NTP, SSH v2, HWTACACS+, RMON, log hosts, and portbased traffic statistics.
4, Fine-grained traffic management
The S5700S-LI supports the Sampled Flow (sFlow) function, which uses a sampling mechanism to obtain statistics about traffic forwarded on a network and sends the statistics to the Collector in real time. The Collector analyzes traffic statistics to help customers manage network traffic efficiently.
Cisco 2611XM
Re: HUAWEI S5700S-LI SERIES GIGABIT ENTERPRISE SWITCHES
Postby hone » Wed Feb 15, 2017 9:59 pm
What is the difference between S5700S and S5700, and I see online that Huawei best seller switch is S5720, I want to buy one in may dataroom, which one is better?
Return to Small Business Switches
