Technical index of Huawei OSN2500 PDU equipment shown in fol
Postby hone » Wed Jan 20, 2016 1:11 am
PDU size DPD100-2-8 442 (wide) x 79.6 (depth) x 110 (high), single cabinet is connected to the voltage (V) for 48 (DC), single cabinet power supply voltage (V) for -38.4 to -57.6, supply current is 4 * 32A; if the single cabinet is connected to the voltage (V) 60 (DC), single cabinet power supply voltage as (V) for 48 ~ 72 supply current for 4 x 20A. The size of the N1PDU for 530 (wide) x 97 (depth) x 133 (high) single cabinet is connected to the voltage (V) for 48 (DC), single cabinet power supply voltage (V) -38.4 to -57.6 supply current is 4 * 20A; if the single cabinet is connected to the voltage (V) 60 (DC), single cabinet power supply voltage as (V) for 48 ~ 72 supply current for 4 x 32A.
HUAWEI OSN2500 equipment power supply requirements 1+1 backup access, two-way power load sharing supply current. According to the distribution principle of the engine room, need to be configured in accordance with the order of the list, so as to ensure that when a failure of the sub frame can be normal power supply. The number of HUAWEI SDH equipment configuration sub frame is sub frame, PDU power input / output decision approach.
Return to Cisco Hardware
