How to remove device
Postby hone » Thu Jan 07, 2016 1:06 am
Under the user view using the reset saved - configuration commands, can remove switch the current user configuration information in the configuration file, after the restart, the equipment will be restored to the factory.
Reset saved - configuration commonly used in the following circumstances: will a have configuration of huawei switches used for new applications, the demand of the original configuration file can not adapt to the new environment, the need to switch to configure, then use the reset saved - configuration can remove the configuration file after the user configuration information, reconfigure the switches.
Introduction :In the configuration reset saved - after the configuration commands, please choose not to save the current configuration file when restart the equipment.
Remove and reconfigurable information can only come into force after the restart the device, the current configuration unchanged.
Re: How to remove device
Postby jorna » Thu Feb 16, 2017 7:10 pm
Huawei switch support Istack? compatible SFP/SFP+ module can be used on?
Cisco 2611XM
Return to Cisco Hardware
