Doubts about HUAWEI OSN8800
Postby jorna » Tue Jan 05, 2016 12:33 am
OSN8800 product description on the transmission distance, so a words: for 40 wave system of 40 Gbit / s to support maximum 20x22dB electric relay transmission specifications. For the 40Gbit/s rate of the 80 wave system, the maximum 18x22dB of the non electric relay transmission specification is supported. For the 10Gbit/s rate of the 40 wave system, the maximum 32x22dB of the non electric relay transmission specification is supported. For the 10Gbit/s rate of the 80 wave system, the maximum 25x22dB of the non electric relay transmission specification is supported. For the 2.5Gbit/s rate, the maximum 25x22dB of the non electric relay transmission specifications are supported. For 10Gbit/s rate system, maximum support 1 x 82dB single span long distance transmission. For the CWDM system, the maximum 80km is supported by the transmission distance. Excuse me, 20x22dB without electric relay transmission, can think so: in loss 0.25dB per kilometers of optical fiber cable and 20*22dB/0.25dB/km=1760km, also is 1760km no electrical relay, without configuration NS2, ND2 line plate electric relay?
Cisco Catalyst 4000
Return to Cisco Hardware
