MDS 9124e "externallydisabled" Status
Postby Guest » Fri Apr 02, 2010 8:16 am
I have two MDS 9124e inside a HP c-class Bladecenter. My problem is, that all internal bay ports have a admin status up, oper status down and a Statusfailurecause "externallydisabled".
The licenses are available and the ports are aquired.
Nevertheless, I found no way to bring them up.
Does anyone can help me?
Kind regards
Christoph
Re:MDS 9124e "externallydisabled" Status
Postby Guest » Fri Apr 02, 2010 8:51 am
The MDS is complaining that they are externally disabled meaning that the bladecentre chassis has them disabled. There should be an option in the HP management screen (OA) to enable the front switch ports.
Postby Guest » Fri Apr 02, 2010 8:56 am
Thanks for the help. I try to find out, where to enable them.
Kind regards
Christoph
Postby Guest » Fri Apr 02, 2010 9:38 am
again hanks for the help.
My actual solution is to remove the existing Br*cade blade switches and place the MDS blades instead.
Now, the ports are available. Now, I can figure out with HP, why this occurs.
Kind regards
Christoph
Return to Storage Networking
