MDS 9506 WWN
MDS 9506 WWN
Postby Guest » Tue Aug 31, 2010 6:26 pm
Hi
I have been told by EMC to find the WWN for the 9506 MDS switch. How would i find this? I thought WWN was port based. is there a WWN for the sup modules or  the Chassis?
Thanks in advance
Re:MDS 9506 WWN
Postby Guest » Tue Aug 31, 2010 6:34 pm
There are wwn's that are on the switch's side of each port and is known as the FWWN. There is also a switch WWN that is an identifier for the switch. That can gotten with this command:
show wwn switch.
Re:MDS 9506 WWN
Postby Guest » Tue Aug 31, 2010 6:46 pm
Is this a new command in the OS. I did not find this on the CLI or is this hidden?. I was told by EMC that the command for this is "Show switch summary" but this was wrong.
thanks in advance
Re:MDS 9506 WWN
Postby Guest » Tue Aug 31, 2010 7:52 pm
No, this is a pretty old  command. Here is one from a lab:
lab9216# show wwn switch
Switch WWN is 20:00:00:0d:ec:27:00:c0
If you are having trouble, can you post your show ver and show wwn switch results?
Re:MDS 9506 WWN
Postby Guest » Tue Aug 31, 2010 9:19 pm
I tried this command and sent it to EMC, they told me that this is not the correct WWN. this is the show version.
Cisco Storage Area Networking Operating System (SAN-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2005, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 1.1.0
  loader:    version 1.2(2)
  kickstart: version 2.1(2b)
  system:    version 2.1(2b)
  BIOS compile time:       10/24/03
  kickstart image file is: bootflash:/m9500-sf1ek9-kickstart-mz.2.1.2b.bin
  kickstart compile time:  8/30/2005 19:00:00 [09/14/2005 09:22:16]
  system image file is:    bootflash:/m9500-sf1ek9-mz.2.1.2b.bin
  system compile time:     8/30/2005 19:00:00 [09/14/2005 09:56:16]
Hardware
  cisco MDS 9506 ("Supervisor/Fabric-1")
  Intel(R) Pentium(R) III CPU - with 1028768 kB of memory.
  Processor Board ID JAE1002TDNU
  bootflash: 500736 blocks (block size 512b)
  slot0:          0 blocks (block size 512b)
  mds9506-1 kernel uptime is 0 days 0 hour 58 minute(s) 22 second(s)
  Last reset
    Reason: Unknown
    System version: 2.1(2b)
    Service:
this is the show wwn switch:
Switch WWN is 20:00:00:0d:ec:24:8a:c0
This is what we gave them and they said its wrong.
Return to Storage Networking
