renaming a switch whilst in production
Postby Guest » Sat Aug 07, 2010 1:06 am
Hi There,
Can i rename a switch whilst it's in Production?We have Cisco MDS 9513 director with SANOS 3.02(b)..If we can then what are the steps to be followed.
Re:renaming a switch whilst in production
Postby Guest » Sat Aug 07, 2010 2:23 am
Hello,
Yes you may rename a switch non-disruptively.
Example:
rtp9513-1-23A-01# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
rtp9513-1-23A-01(config)# switchname Test-Name
Test-Name(config)# switchname rtp9513-1-23A-01
rtp9513-1-23A-01(config)# exit
rtp9513-1-23A-01# copy run start
[########################################] 100%
rtp9513-1-23A-01#
Thanks,
Nikhil
Postby Guest » Sat Aug 07, 2010 3:54 am
Be advised that renaming a switch does generate an RSCN, unless the switch is configured to not do so.  By design, the RSCN being generated should cause no impact.
Return to Storage Networking
