User restrictions-pix/asa
Postby Guest » Thu Dec 16, 2010 9:33 pm
PIX/asa  I have created user with privilege level, how can i restrcit the according to the privilege level .
example privilege level 10 they should not enter in config mode.
pl advise
thanks
Karthik
Re:User restrictions-pix/asa
Postby Guest » Thu Dec 16, 2010 10:15 pm
You should enable Local command Authorisation to achive this. Refer this link to enable Local Authorisation and configuration steps.
http://www.cisco.com/en/US/docs/security/asa/asa72/configuration/guide/mgaccess.html#wp1042039
Users browsing this forum: Majestic-12 [Bot] and 2 guests
