problem installing CSD secure desktop in ASA 8.0(2)
I am trying to setup securedesktop 3.2.0.136 on ASA5510 running 8.0(2) with ASDM 6.0(2). I get this error when I try to install it.ERROR: Unable to use CSD image. Try another.I did sh webvpn csd image to validate the file and it seems ok. I've tried to redownload it from the cisco site, but getting the same error. Is the file messed up?
Re:problem installing CSD secure desktop in ASA 8.0(2)
I'm also experiencing this problem but with 7.2(2) as I didn't catch that 3.2 was for >=8.0. Now when I try to install CSD 3.1.x I get the same error as above.
Same thing here :Activating CSD in ASDM give :-Start-[OK] webvpn webvpn[ERROR] csd enable Unable to use CSD image. Try another-End-ASA : 7.2(2)ASDM : 5.2(2)CSD IMAGE : securedesktop-asa-3.1.1.45-k9.pkgorsecuredesktop-asa-3.2.0.136-k9.pkgHere is what i've done ( After the failure in ASDM)asa-*****# show webvpn csd image disk0:/securedesktop-asa-3.1.1.29-k9.pkgThis is a valid Cisco Secure Desktop image:Version : 3.1.1.29Built on : Tue 04/18/2006 10:19:43.03asa-*****# conf tasa-*****(config)# webvpnasa-*****(config-webvpn)# csd image disk0:/securedesktop-asa-3.1.1.29-k9.pkgasa-*****(config-webvpn)# csd enableERROR: Unable to use CSD image. Try anotherPrivilege Level : 15Enough free space on flash.Any idea?
License problem?I have a base license.
I have base license comes with 2 SSL VPN, and 250 vpn, with CSC as well.
