ASA 7.2(2) and snmp
ASA 7.2(2) and snmp
Postby Guest » Thu Nov 25, 2010 6:23 am
Hi all, I just put 7.2(2) software on a ASA 5540. I have some snmp servers on the outside interface. When I configure these server there is no problem, but then I can't save configuration because i get an error:
1# wr mem
Building configuration...
Cryptochecksum: xxx
%Error reading system:/running-config (Configuration line too long)
Error executing command
[FAILED]
Is this a bug or did syntax change?
Re:ASA 7.2(2) and snmp
Postby Guest » Thu Nov 25, 2010 7:14 am
How big/long your ASA configuration? The error message in bracket "Configuration line too long" may be a clue for the error.
Try to remove the newly added lines, or any less important parameres, save it and see if you get the same error again.
HTH
AK
Postby Guest » Thu Nov 25, 2010 7:48 am
It's not a configuration lenght problem, adding or removing other lines has no effect.
It's just with "snmp-server Outside ...."
Thank you anyway
Postby Guest » Thu Nov 25, 2010 9:03 am
It is a bug. Configure max 3 snmp servers, or max 6 snmp servers, it depends on soft version.
Postby Guest » Thu Nov 25, 2010 9:14 am
I ran into the same problem on our ASA5520 on v7.2(2).  We had 7 snmp servers on our pix515e's on 6.35 that we replaced with the ASA's.  We had to pair our snmp server list down to only 3  :(
Can the undo snmp-agent trap enable Command?
Forum: Network Management
Author: jorna
SNMP server configuration
Forum: Routing Protocols
Author: m_1607
Reload module via snmp
Author: Anonymous
6509 SNMP Setup for Use with CiscoWorks 2000
Forum: Anything Networking
Author: Anonymous
SNMP Traps - Warmstart
Author: Anonymous
Users browsing this forum: Google [Bot] and 1 guest
