Number of interface ASA5510
Postby Guest » Thu Dec 23, 2010 1:53 am
Just a short question:
Does the 5510 Security Plus ASA support totally 15 interfaces (5 x phy. and 10 x virtually) or just totally 10?
thanks for the feedback
Oliver
Re:Number of interface ASA5510
Postby Guest » Thu Dec 23, 2010 2:16 am
Oliver,
It can support 10 additional VLAN interfaces with the existing 5 physical interfaces. One of the physical interface will be used as a trunk for VLAN configuration... You can max use 15 interfaces, though i would normally think of using 14 max (as 1 interface goes for trunk)
Hope this helps... rate replies if found useful
Raj
Users browsing this forum: Majestic-12 [Bot] and 3 guests
