VPN through PAT and NAT
Postby Guest » Tue Dec 14, 2010 8:06 pm
We've got a location where we want to setup a VPN-tunnel to our HQ.
At that location, there's a router which does PAT (NAT overload), and then, some hops further, there's a firewall which does NAT.
Could this pose a problem to the VPN-tunnel?
Here's a 'diagram' of what the connection looks like.
Client -->PAT-router-->NAT firewall-->Internet-->CVPN3005
Hopefully you can provide me with an answer.
Re:VPN through PAT and NAT
Postby Guest » Tue Dec 14, 2010 8:37 pm
i don't think there would be an issue.
one thing should be noticed is when a host from the cvpn site needs access the the remote site, than a static nat needs to be configured on the router.
Postby Guest » Tue Dec 14, 2010 9:05 pm
ok, that's a plus.
If I'm not mistaken, the tunnel uses UDP-port 500 and UDP-port 4500 if I'm using NAT-T (which I must because of the NAT at the firewall).
Could there be more ports needed because of the PAT and NAT?
Postby Guest » Tue Dec 14, 2010 10:03 pm
udp 500 = isakmp
udp 4500 = non-isakmp
ip 50 = esp
Postby Guest » Tue Dec 14, 2010 11:43 pm
Is that correct? When using NAT-T as far as I know ESP is encapsulated in the traffic on UDP-port 4500?
ESP or AH cannot be NATted, as far as I know...
