SSL VPN CLIENT ERROR!
Postby Guest » Sat Jan 01, 2011 8:23 am
VPN Concentrator is running 4.7. I login to the web vpn session. The SSL VPN Client installs. Message appears that says "Waiting while the SSL VPN connection is established" and thereafter another message appears that says "SSL VPN HTTP RESPONSE received from the gateway is invalid".
What is strange is that the VPN concentrator lists me as logged in with an assigned IP address from the ACS, however I can not access anything. BTW no WEB ACLs or IP filters are configured for this group that would not allow me access on the network. Furthermore with the same credentials and the same group I have no problem accessing the network when the SSL VPN client is not configured to be used. ie web vpn prior to 4.7.
Any ideas?
Re:SSL VPN CLIENT ERROR!
Postby Guest » Sat Jan 01, 2011 8:38 am
The message "SSL VPN HTTP RESPONSE received from the gateway is invalid" can appear if concentrator's client configuration contains more than split tunneling 26 entries.
Postby Guest » Sat Jan 01, 2011 10:01 am
That did it. I had 27 entries and deleted a couple and that worked fine. Thanks.
