Confused about ASA 5505 Base license
Postby Guest » Wed Dec 08, 2010 3:46 pm
Does the ASA 5505 base license somehow limit how many 'inside' subnets you can have if they are configured on a layer 3 switch that is connected to the ASA5505? I know I can only configure 3 VLAN's on the ASA -- but I didn't think it prohibited me from using multiple VLAN's on my switch...
Re:Confused about ASA 5505 Base license
Postby Guest » Wed Dec 08, 2010 4:12 pm
No it doesn't restrict the number of subnets behind it. Depending on your user license it will limit how many users can traverse the firewall. A show version will show how many users you're licensed for. Also make sure you have all the routing in place in your ASA.
