VPN Connectivity to an offline server.
Postby Guest » Wed Dec 01, 2010 10:43 am
Greetings All,
I am trying to bring standard site to site vpn connection between two sites. Site A and Site B.
Site A has a server (SeverOne)and site B WILL have a server (ServerTwo).
Now Im trying to bring up the VPN tunnel by pinging at this point a NON-EXISTENT server (ServerTwo) from the ServerOne.
SO the question is will this tunnel come up even though the server at site B is still not online? So far my tunnel is not passing phase 1.
Thanks in advance
Re:VPN Connectivity to an offline server.
Postby Guest » Wed Dec 01, 2010 11:06 am
Absolutely.. tunnel should still come up even though the host at other end does not respond.. you still should see phase 1/2 complete, and note in the output of (show crypto isakmp sa) in your firewall tunnel state as QM_IDLE and see peer tunnel address and your tunnel address..   you will only see encrypts but no decryps in the output of (show crypto ipsec sa) when sending pings to a system that is not online ...  so if your tunnel makes it as far as phase1  something is wrong , either in your ike policy not matching or peer not responding..
Postby Guest » Wed Dec 01, 2010 11:31 am
I know it's been a year (almost) but thanks.. this was helpfull
CCM server QoS
Forum: Quality of Service
Author: Anonymous
SNMP server configuration
Forum: Routing Protocols
Author: m_1607
Two networks, One Server
Author: silverskymedia
ASA5510 Remote access Server problem
Forum: Virtual Private Networks
Author: Anonymous
Ping to PAT internal server on ASA 5510
Forum: Cisco Security
Author: Anonymous
