PPPoE multiple profiles for VPDN
Postby Guest » Wed Nov 24, 2010 5:40 am
I'm trying to set up a single router to terminate PPPoE connections and offer different rates using virtual templates. All the documentation seems to be focused on LAC/LNS installs. In this case we effectively just have a single router performing both functions.
RADIUS will be used for AAA.
Re:PPPoE multiple profiles for VPDN
Postby Guest » Wed Nov 24, 2010 6:12 am
It should look something like this:
aaa authentication ppp vpdn group radius
aaa authorization network vpdn group radius
aaa accounting network vpdn start-stop group radius
bba-group pppoe VPDN1
virtual-template 10
sessions auto cleanup
bba-group pppoe VPDN2
virtual-template 20
interface GigabitEthernet0/1.10
encapsulation dot1Q 10
ip unnumbered Loopback0
pppoe enable group VPDN1
interface GigabitEthernet0/1.20
encapsulation dot1Q 20
pppoe enable group VPDN2
interface Virtual-Template10
description VPDN1
ppp authentication pap vpdn
ppp authorization vpdn
ppp accounting vpdn
description VPDN2
ppp accounting vpdn
radius-server host <IP address of the AAA server> <key>
And you can do whatever you want under each virtual-template.
BR,
Mohammed Mahmoud.
Postby Guest » Wed Nov 24, 2010 6:56 am
This is similar to the sample configs I've been looking at however I can't see how service is differentiated based on login details. I would appear to differentiate based on the incoming VLAN.
What I'm trying to do is have a user login using PPPoE and be given a virtual template based on their RADIUS profile. The idea being that I can a embed QoS policing policy in the virtual template to provide different service levels to customers.
Postby Guest » Wed Nov 24, 2010 7:14 am
AFAIK, to apply a different virtual-template you need to apply a different bba-group, and to apply a different bba-group you need to use VLANs and subinterfaces - i think that you can work around and use this model.
Another prospective to think with, is that you can search if what you require to do can be sent by the RADIUS as a Cisco RADIUS AV Pair according to the customer profile.
BR,
Mohammed Mahmoud.
Postby Guest » Wed Nov 24, 2010 7:54 am
I understand that it is a RADIUS AVP, the question being how to apply it.
D
