Problems with PVDM2 in a 2800 with E1/T1 Module
Postby Guest » Sat Dec 11, 2010 5:56 pm
Hello,
I have a 2800 with an E1/T1 Module and PVDM2 Modules and want to dial out over a telnet connection to the modem line.
The "show line" command shows only VTY lines and no TTY lines to connect to.
The modems are in the pvdm0 Slot of the E1 Card.
We have had no such problems doing this with the same E1/T1 Card and NM-xDM( Mica Modems ) in several 3800 Routers.
thank you very much for your help
Klaus Hebel
Here is the configuration:
yourname#show inventory
NAME: "2811 chassis", DESCR: "2811 chassis"
PID: CISCO2811         , VID: V05 , SN: FCZ1138713M
NAME: "High Density Voice2 Network module with on board one port interface ", DESCR: "High Density Voice2 Network module with on board one port interface "
PID: NM-HDV2-1T1/E1    , VID: V03 , SN: FOC11402PXV
NAME: "PVDMII DSP SIMM with Two DSPs", DESCR: "PVDMII DSP SIMM with Two DSPs"
PID: PVDM2-32          , VID: V01 , SN: FOC11416WU0
yourname#show run
Building configuration...
Current configuration : 4058 bytes
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname yourname
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-18.bin
boot-end-marker
card type e1 1 1
logging buffered 51200 warnings
no aaa new-model
no network-clock-participate slot 1
ip cef
ip domain name yourdomain.com
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
isdn switch-type primary-net5
voice-card 0
no dspfarm
voice-card 1
no dspfarm
controller E1 1/0
pri-group timeslots 1-31
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$
ip address 172.16.1.119 255.255.240.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial1/0:15
no ip address
encapsulation hdlc
isdn incoming-voice modem
no fair-queue
no cdp enable
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
access-list 23 permit 10.10.10.0 0.0.0.7
control-plane
voice-port 1/0:15
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
yourname#
Re:Problems with PVDM2 in a 2800 with E1/T1 Module
Postby Guest » Sat Dec 11, 2010 7:10 pm
Hi, the pvdm2 that you have support only voice calls and do not support modem calls.
The modem module in pvdm2 form has part number pvdm2-xdm where x can be 8, 16 or 32.
You also need the NM-CE1/T1 module, or the new hwic-1cet1-pri, or the vic2-2bri-nt/te to connect to telco.
Hope tis helps, please rate post if it does
Postby Guest » Sat Dec 11, 2010 7:13 pm
Thank you very much for your quick help!
Postby Guest » Sat Dec 11, 2010 8:12 pm
You're welcome, thanks for the nice rating and good luck!
Users browsing this forum: No registered users and 4 guests
