Dial up 7206VXR
Dial up 7206VXR
Postby Guest » Mon Jan 03, 2011 9:50 am
Can we configure 7206VXR with PA-MCX-8T/E1 and E1 PRI for PSTN dialup users without any modem card?
Re:Dial up 7206VXR
Postby Guest » Mon Jan 03, 2011 11:10 am
I am not sure but I think you have to have a modem card otherwise how and where the router will forward the call. We use command " incoming voice modem " specially to have the ISDN PRI detect the analog call and forward it to internal modems.
HTH,
-amit singh
Re:Dial up 7206VXR
Postby Guest » Mon Jan 03, 2011 11:27 am
Hello,
I aggree with you, you should need some modem like mica ones to handled the PSTN calls.
Users browsing this forum: No registered users and 6 guests
