Why the dhcp select global Command Is Added to the VLANIF ?
Postby jorna » Thu Jul 28, 2016 6:48 pm
By default, the DHCP service is enabled using the dhcp select global command in the VLANIF interface view in S2700/S3700/S5700 V100R003 and disabled in V100R005. To ensure that V100R005 is compatible with earlier versions, the DHCP service is enabled in V100R005. If the global DHCP service enabled using the dhcp enable command is disabled, the related commands do not take effect. It is recommended that you delete these commands manually. If the global DHCP service is enabled, contact Huawei technical support engineers to delete related commands.
Cisco 2611XM
Return to Cisco Switching
Users browsing this forum: No registered users and 5 guests
