Details about terminal user password
Postby jorna » Mon Jul 18, 2016 6:29 pm
Function
This command is used to modify the password of a user for the device. Proper user passwords ensure the system security. After the command is executed successfully, the original password is invalid.
Format
Parameters
None
Modes
Privilege mode
Level
Common user level
Usage Guidelines
To enhance system security, change the password to meet the requirement after the first successful login. It is recommended that you change the password periodically.
Before modifying the password of a user, run the display terminal user command to query the name of the user whose password is to be changed.
The super user and administrator can modify their own passwords and the password of the user with lower level. When modifying the password of the user with lower level, the super user or administrator needs to input the name but not the previous password of the user.
Except the administrator, all users can only modify their own passwords and are required to input the previous passwords.
The input password is not displayed on the terminal.
An entered password cannot be the same as a password entered in the latest five times.
Example
To modify the password of common user "test-user1" through an administrator account, do as follows:
huawei#terminal user password
User name (<=15 chars):test-user1
New password(length<6,15>):
Confirm Password(length<6,15>):
Information takes effect
Repeat this operation? (y/n)[n]:nTo modify the password through a common user account, do as follows:
Old password(<=15 chars):
Repeat this operation? (y/n)[n]:nSystem Response
The system displays the message "Information takes effect" after the password of a user is modified successfully.
The following table describes the parameters in the response to the terminal user password command.
Parameter
Description
User Name
Indicates the user name.
New password
The password must contain at least x characters. The maximum value of "x" is 15 characters and the default value is 6 characters (the minimum password length for user root or security is 8 by default). You can run the system user password security-length command to change the value of "x". The password must:
Contains at least one digit and one letter.
Not contain a question mark (?).
Be case insensitive.
Be different from the user name.
Not the characters of the user name in reversed order.
Common passwords, such as password, admin, and 123456, are not used.
Confirm Password
Confirms the password.
Indicates whether to repeat this operation, with "y" for yes and "n" for no.
For more information about the error message that the system displays against a command entered with incorrect syntax, see the "Syntax Check" in Parameter.
S2700,S2700-9TP-SI-AC
Cisco Catalyst 4000
Return to Cisco Switching
