cisco 7206VXR router keep booting on older IOS
Postby Guest » Thu Sep 30, 2010 3:23 pm
Hi.
I wanted to boot a cisco 7206VXR router on IOS c7200-is-mz.124-18e.bin.
However the router keep booting on the older IOS c7200-is-mz.122-15.B.bin.
The configuration/status before I reload:
1. Configuration register is 0x2102
2. gw-btvoice-sto2#sh run | in boot sys
boot system flash disk2:c7200-is-mz.124-18e.bin
3. gw-btvoice-sto2#sh bootvar
BOOT variable = disk2:c7200-is-mz.124-18e.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
4. gw-btvoice-sto2#sh disk2:
-#- --length-- -----date/time------ path
1     16371056 Apr 05 2009 17:51:12 c7200-is-mz.122-15.B.bin
2     26009164 Mar 31 2009 06:55:32 c7200-is-mz.124-18e.bin
21823488 bytes available (42401792 bytes used)
5. verify /md5 disk2:c7200-is-mz.124-18e.bin provides the correct checksum
gw-btvoice-sto2#sh version
Cisco Internetwork Operating System Software
IOS (tm) 7200 Software (C7200-IS-M), Version 12.2(15)B, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Fri 31-Jan-03 01:13 by leccese
Image text-base: 0x60008954, data-base: 0x61BEC000
ROM: System Bootstrap, Version 12.2(8r)B, RELEASE SOFTWARE (fc1)
BOOTLDR: 7200 Software (C7200-IS-M), Version 12.2(15)B, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
gw-btvoice-sto2 uptime is 12 hours, 56 minutes
System returned to ROM by reload at 20:28:35 CET-DST Sun Apr 5 2009
System restarted at 20:30:17 CET-DST Sun Apr 5 2009
System image file is "disk2:c7200-is-mz.122-15.B.bin"
cisco 7206VXR (NPE-G1) processor (revision A) with 245760K/16384K bytes of memory.
Processor board ID 23675723
SB-1 CPU at 700Mhz, Implementation 1, Rev 0.2, 512KB L2 Cache
6 slot VXR midplane, Version 2.1
Last reset from watchdog reset
Bridging software.
X.25 software, Version 3.0.0.
3 FastEthernet/IEEE 802.3 interface(s)
3 Gigabit Ethernet/IEEE 802.3 interface(s)
509K bytes of non-volatile configuration memory.
62976K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
gw-btvoice-sto2#sh file systems
File Systems:
     Size(b)     Free(b)      Type  Flags  Prefixes
           -           -    opaque     rw   system:
           -           -    opaque     rw   null:
           -           -   network     rw   tftp:
      522232      513430     nvram     rw   nvram:
           -           -      disk     rw   disk0:
           -           -      disk     rw   disk1:
           -           -     flash     rw   slot0: flash:
           -           -     flash     rw   slot1:
*   64225280    21823488      disk     rw   disk2:
    15990784    10852728     flash     rw   bootflash:
           -           -   network     rw   rcp:
           -           -   network     rw   pram:
           -           -   network     rw   ftp:
gw-btvoice-sto2#sh bootflash:
-#- ED ----type---- --crc--- -seek-- nlen -length- -----date/time------ name
1   .. image        A4DAD420  526688   23  5137928 Jan 23 2000 02:33:13 c7200-kboot-mz.122-4.BW
10852728 bytes available (5138056 bytes used)
Re:cisco 7206VXR router keep booting on older IOS
Postby Guest » Thu Sep 30, 2010 4:10 pm
Hello Simon,
you may need to load a newer boot loader code in the bootflash to be able to load the new image.
You see that you hace a 12.2(4) boot loader in bootflash c7200-kboot-mz.122-4.BW
try to copy in bootflash the appropriate boot loader for the new image and to set the boot loader image
Hope to help
Giuseppe
Postby Guest » Thu Sep 30, 2010 4:33 pm
Hello Giuseppe
I will try your suggestion tonight. I keep you informed. thanks simon
Postby Guest » Thu Sep 30, 2010 5:32 pm
I tried your suggestion with no success.
I copied c7200-kboot-mz.124-18e.bin into the bootflash. This was the situation when I reloaded
BOOTLDR variable = bootflash:c7200-kboot-mz.124-18e.bin
Untill now I reloaded from remote but decided to reload from the console. One of the first thing displayed on the console is
string is disk2:c7200-is-mz.122-15.B.bin
I don't know where this string is set but this must be the reason why the boot cmd's have no impact. Here is the output from the reload
gw-btvoice-sto2#reload
Proceed with reload? [confirm]
Copyright (c) 2002 by cisco Systems, Inc.
C7200 platform with 262144 Kbytes of main memory
Self decompressing the image : #########################################################################################
######################################################################################################### [OK]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Bridging software.
regards
simon
Postby Guest » Thu Sep 30, 2010 6:04 pm
Hi Simon,
Remove Disk2:.
Return to Cisco Switching
Users browsing this forum: Google Adsense [Bot] and 3 guests
