NSSA ABR not translatingType 7 LSAs to Type 5
Re:NSSA ABR not translatingType 7 LSAs to Type 5
Post by Guest » Sun Dec 27, 2009 7:20 am
http://www.ietf.org/rfc/rfc1587.txt4.1 Translating Type-7 LSAs Into Type-5 LSAs   This step is performed as part of the NSSA's Dijkstra calculation   after type-5 and type-7 routes have been calculated.  If the   calculating router is not an area border router this translation   algorithm should be skipped.  All reachable area border routers in   the NSSA should now be examined noting the one with the highest   router ID.  If this router has the highest router ID, it will be the   one translating type-7 LSAs into type-5 LSAs for the NSSA, otherwise   the translation algorithm should not be performed.
Post by Guest » Sun Dec 27, 2009 7:37 am
yes..this makes sense and this is exactly the situation i have but for some reason conversion is not happening on the NSSA ABR...
Post by Guest » Sun Dec 27, 2009 7:52 am
on both NSSA ABRs, or only on one of them?
Post by Guest » Sun Dec 27, 2009 7:58 am
well only one ABR (with the highest RID) is designated with translating the LSAs and it's not doin in
Post by Guest » Sun Dec 27, 2009 8:26 am
could you show the configurations?
