Which Default Passwords Are Used on S Series Switches?
Postby jorna » Wed Feb 08, 2017 5:41 pm
On the S series switchesof all versions:
When you log in a switch through a console port, no default user name or password is provided. The system asks you to set the user name and password when you log in to the switch for the first time.
Before you log in to a switch through Telnet, create a Telnet account.
You can set the Telnet login authentication method in the VTY. If the password authentication mode is configured, set a password in the VTY. If the AAA local authentication mode is configured, set the user name and password in the AAA view. If the remote AAA authentication mode is configured, set the user name and password on the AAA server.
For other default passwords, see Table 1.
NOTE:
By default, the console login password, BootROM password, and Telnet password are case-sensitive.
The S12700&S5720EI&S5720HI use the BootLoad menu, but not the BootROM menu.
When you log in to a switch through web, your default user level is 0: visit level.
Cisco 1760
Re: Which Default Passwords Are Used on S Series Switches?
Postby hone » Tue Mar 21, 2017 7:43 pm
Huawei switch is cost-effective compared to other brand switch.
Cisco Catalyst 3560
Users browsing this forum: No registered users and 4 guests
