How Do I Configure the Telnet Login Function?
Postby hone » Thu Jan 12, 2017 10:42 pm
You can log in to a switch through Telnet only when the switch has an IP address and the VTY user authentication method and VTY user level have been configured. By default, the preceding configurations are unavailable on the switch, and you must log in to the switch through the console interface and complete the configurations.
Perform the following configurations:
Set a management IP address for the switch.
# If the switch has an management interface, configure an IP address for the management interface.
<HUAWEI> system-view
[HUAWEI] interface meth 0/0/1
[HUAWEI-MEth0/0/1] ip address 192.168.1.2 24
[HUAWEI-MEth0/0/1] quit# If the switch has no management interface, configure an IP address for the WLANIF interface.
[HUAWEI] vlan 4094
[HUAWEI-vlan4094] quit
[HUAWEI] interface gigabitethernet 0/0/48
[HUAWEI-GigabitEthernet0/0/48] port link-type hybrid
[HUAWEI-GigabitEthernet0/0/48] port hybrid untagged vlan 4094
[HUAWEI-GigabitEthernet0/0/48] quit
[HUAWEI] interface vlanif 4094
[HUAWEI-Vlanif4094] ip address 192.168.1.2 24
[HUAWEI-Vlanif4094] quitConfigure reachable routes between the PC and switch so that the PC can successfully ping the switch.
If the PC is directly connected to the switch, ensure that the IP address of the PC is in the same network segment as the management IP address of the switch.
If the PC is not directly connected to the switch, configure reachable routes between the PC and switch.
Set the authentication mode for Telnet login to AAA.
[HUAWEI] user-interface vty 0 4
[HUAWEI-ui-vty0-4] authentication-mode aaa
[HUAWEI-ui-vty0-4] quit
Configure the Telnet login user parameters. Set the user name and password to admin@6789, and user level to 3.
[HUAWEI] aaa
[HUAWEI-aaa] local-user admin password irreversible-cipher admin@6789
[HUAWEI-aaa] local-user admin privilege level 3
[HUAWEI-aaa] local-user admin service-type telnet
Cisco Catalyst 3560
