Can the S Switches Use AC and DC Power Supply Simultaneously
Postby hone » Tue Jan 03, 2017 10:16 pm
In versions prior to V100R006C01, the S2700, S3700, and S5700 cannot use AC and DC power supply simultaneously.
In V100R006C01 and later versions, the S3700-26C-HI, S5700-28C-HI, and S5700-28C-HI-24S can use AC and DC power supply simultaneously. S6700 cannot use AC and DC power supply simultaneously.
In V200R001C00 and later versions, the S5710-28C-EI and S5710-52C-EI can use AC and DC power supply simultaneously.
In versions prior to V200R005C00, the S6700-EI cannot use AC and DC power supply simultaneously.
In V200R005C00, the S5700-EI (non-PoE), S5700-SI (non-PoE), and S6700-EI can use AC and DC power supply simultaneously.
In V200R006C00 and later versions, the S5720-HI (non-PoE) can use AC and DC power supply simultaneously.
In V200R007C00 and later versions, the S5720-C-EI (non-PoE) and S5720-PC-EI (non-PoE) can use AC and DC power supply simultaneously.
The S5720-SI (non-PoE) and S6720-EI newly available in V200R008C00 can use AC and DC power supply simultaneously.
Cisco Catalyst 3550
